paving slabs 350mm or 700mm
12 Jun 2007
Essex
does anyone know of a paving slab either 350mm wide or 700mm wide.
hi thermo,i am laying a path 700mmx10mts,dont know what type i want it depends on price.
as you probably realise most paving is manufactured to 150 increments, so youre unlikely to get a precast one to that size. the best option would be to go for something like indian sandstone, which is fairly easy to cut. they do slabs 900 x 600 so they can be easily cut down to size, assuming you dont want joints in teh path. otherwise use smaller slabs to make up the width, with the cutting. either way, youll be doing some cutting!
Can u not alter the width of the path to natch the slabs u like? or find an edging block to fit along either edge?
