Not sure if this is in the right bit(Plumbing?), but our house came with the bogs and sinks attached to the floor direct.
We had just used vinyl but the time has come to do it properly to last and having read the very useful "sticky" it advises 12mm WBP+adhesive+tile thickness?
So, that will raise the level 20-25mm? I can remove the pedestal and the toilet can be unscrewed(probably a push fit set of pipes?)
Can anyone advise what's best in this situation? If I go under which is what I want it looks like a set of hassles, but I don't want to cut around them either as I think it would be cleaner in terms of looks and hygiene?
Do pro tilers just cut around them?
I've got a grinder and could make templates to cut tiles, if I did this it might not be so bad(stonemason used to cutting things! )
(Any advice appreciated, there's not any play in either so that means they'd need removed and repositioned?)
Cheers
Cheers
