Peglar part 2 ball valve
5 Feb 2006
I just bought this valve hoping for something reasonably well made. It seems like there is quite a bit of sideways play in the arm (so that if you really forced it you could probably move the base of the arm past the piston thing so that the valve wouldn't close!) but I don't know if that is normal.
Also, no washers are supplied. Does that mean I have to get some washers of the right size from somewhere to sit either side of the CW tank?
Thanks in advance as ever for any constructive comments.
http://www.screwfix.com/p/pegler-prestex-float-valve-part-2/27627#
You will have no problem with that valve so long as it has a brass piston thing and not a plastic one.
1/2" polywashers from any merchant or "shed".
