- Joined
- 3 Dec 2023
- Messages
- 3
- Reaction score
- 0
- Country
Hi everyone,
About a month or two ago we noticed that the F and E was overflowing quite a bit. We also had some rusty coloured water. I can see now from research that this would naturally point to a hole in the coil.
I had a plumber out, who I wouldn’t use again because he seemed completely useless. He put some chemicals in the radiator to clean them out. That instantly bled in to the hot water, which my kids couldn’t bath in, so he came & flushed it out. He said the fact it bled in to the hot water pointed to a coil hole & that we’d need a new cylinder.
Without going in to the reasons, we have 0 money & wont have any for a good while yet. I can’t get a plumber back any time soon. As a cheap fudge attempt, we bought two bottles of miracle seal & put them in to the system. We no longer have discoloured water & the miracle seal didn’t blead in to the hot water like the chemicals the plumber used did. So we thought maybe we’d fixed the hole. But the f and e is still regularly overflowing. Obviously the biggest concern I have is that we’re in winter now. Even though the f and e water is often / mostly warm & that the water runs or drips & therefore may not be as susceptible to freezing up, it’s still a major concern.
Theres also a lot of gurgling / crackling in the pipes & the upstairs radiator needs bleeding every day. The f and e ballcock seems fine from what I can see.
I have no idea what to do as I am useless with anything practical & have 0 knowledge of plumbing. I’m losing sleep over this though. I’m baffled a bit about the miracle seal because even though it hasn’t stopped the overflow, it did stop the discolouration.
Any ideas on any potential simple fixes that won’t involve using a plumber? I’m sure there aren’t, but it’s worth asking. We have an immersion heater too, but I guess that wouldn’t make much difference if we used that in place of the range cooker that we usually use to do the hot water & heating..
Thanks to anyone kind enough to reply..
