Pergola Post
24 Oct 2006
Cambridgeshire
I am intending to build a Long pergola, which will have 20 4"x4" post, 10 on each side. The cost of normal 9ft posts is fine, but if u want a slot cut in the top they appear to be about £10 dearer, so for 20 posts it adds up. Is there a simple way of cutting accurately the slots in the posts.
:wink:
Thanks for the answer !!!, I've tried that before and can't seem to get nice 90deg corners , etc. Was looking for something a bit more scientific.
i take it your cutting a slot for the top member to sit in? You need to remember with sawn exterior wood that it is not planed smooth or accuratly so you will never get perfect joints when it comes to carpentry of that type.
well if you dont trust your own chippy skills (i have a similar problem with chippy skills) why not lay them on the top and screw through from underneath at an angle
or from the top for that matter (and a dob of silicone selant to stop water getting in)
i normally screw them in from the side to cover the tops of the posts and then half lap the cross members
Dont bother worrying yourself over sharp 90 deg corners - these sort of projects look rustic at the best of times, and as soon as plants grow up the structure it'll never notice. As stated, sawn timber is not very square to start with.
