Hi all, I am sure I have seen similar posts about this on here before, but I can't find them again, so apologies for repeating this again.
I am building an attached garage and utility room, with a 100 mm cavity wall. The outer leaf is in brick, the inner in block.
I am now ready to start building up from floor level but am not sure how to finish the cavity before I begin.
1. I understand I should fill the bottom of the cavity with a sand and cement mix, but to what level, and what mix ratio?
2. This sand and cement mix should slope downwards to the outer leaf, but by how much?
3. I will be using a 50 mm Kingspan or similar insulation, how far down the cavity should this extend - to DPC level, or right down to the sand cement mix mentioned above?
4. Should I put weep vents in the bottom of the cavity (at ground level)? I know this is a contentious subject amongst some of you but I thought I should ask all the same!
Any pics/diagrams of the above would be appreciated.
Many thanks in advance for your replies,
Ellwood
Ellwood
