I have always been convinced that a little knowledge about something is more dangerous than no knowledge at all. It gives people the confidence to think they know what they are doing...
I posted here a while back with some questions about the cooker for new new kitchen. Well today I started stripping all the old units out in preparation for the electrician who is coming tomorrow ahead of the kitchen fitters on Monday. Having seen the standard of some of the electrical work I have already had replaced elsewhere in the property I was prepared to find a a bit of a mess, but what I did find after stripping the walls back surprised me.
Firstly perhaps the least unusual, and probably perfectly safe except there was no grommet on the cable entry. I hadn't noticed it until today because it was beind the microwave, but the old fridge and freezer were running off an extension lead plugged into an above counter double socket, but installed under the worktop:
Then on to another double socket, which had obviously been moved at some point but the person doing it couldn't be bothered to replace the cable (easy to do as it is in conduit running up the wall to the roof space above). What puzzles me is why the cable has then been extended a second time. It is also taken from the ring as a spur, which then feeds another double socket nearby (that is the cable exiting the box at the bottom). The earth strands were not sleeved, and I am too afraid to undo the tape incase I make it any more dangerous than it is. When the electrician removes it I will be sure to take a photo without the tape present:
Now for the extraction fan above the cooker. This appears to be run from a single switched socket that is fitted on the ring main. No problem there, except that the socket is mounted directly to wires that just emerge from the wall, parcel tape was wrapped around the whole lot to stop it making contact with the metal extraction fan 'chimney' and the plug was inaccessible should the fuse blow:
Finally on to my personal favourite - the cooker connection unit. It is on a dedicated 30amp 6mm radial, but again has been moved at some point in the past. Rather than replace the cable (again easily accessible to do so) the old CCU has been left in place and a new length of cable fitted between it and the CCU behind the cooker. There is no isolator on this circuit except for the main MCB. The old CCU had no back box and was wedged into position by the tile adhesive loaded over the top of it:
There are also numerous instances where holes have been drilled and plugged within safe zones, although I believe they all missed the cable conduits. One instance is directly above the centre of a double socket, but fortunately the cable was off centre. This is all on one wall, I haven't started on the other yet, and I have yet to work out where the old dishwasher is being fed from...
I think Part P should have been included in the regs a long time ago. I wonder how many people unknowingly have installations like this in their houses?
