Can someone please indicate which way round the photoresistor should be installed on a Trianco Eurostar oil boiler with a Stirling burner assembly, The resistor is keyed to its holder, so only fits one way. The connecting plug has D shaped polarizing pins but actually fits either way!
The photoresistor has an end and side window, should the side window face the oil pump or the control unit? Once this is resolved, which way should the brown and blue lead be connected i.e. brown or blue to the top?
I cannot just try and find out which way by trial and error because the boiler has another problem which is causing lockout within a few seconds after firing up. I have to be sure the photoresistor is connected correctly before I can investigate the lockout problem elsewhere.
