I take it it wasn't some rubbish emergency feed or anything?
Did you get zapped?
Why not use a multimeter, far more reliable. .
Multimeters are not approved voltage testers !
Multimeters can be set wrongly and are more fiddly to hold. If, due to experience, I suspected a casing might be live I would be isolating in the first instance and using the voltage tester to prove dead.
If I felt the need to test all future casings then I would still want to use my approved voltage tester to test for live in the same way as I would test for dead.
The problem arises when you have to find a satisfactory earth to reference test it to.
This seems to be a cause for concern. If you are not 100% confident that you've found an adequate earth (and establishing that would, in itself, theoretically require some other testing) there is surely the risk of getting a dangerously misleading result with a voltage tester? Do you think there's a case for undertaking a secondary test with a volt stick (or even a neon screwdriver!) in cases in which one is not 100% confident about the earth.The problem arises when you have to find a satisfactory earth to reference test it to.
After he had initially tested I had a rather patronising explanation of how electricity always finds the easiest path to earth
A statement which can be heard repeated regularly, but which is not strictly true. First, electricity will take all available paths to complete the circuit; it's just that the "easiest" path (i.e. the path of lowest impedance) will carry the largest proportion of the current.
Second, to say that "electricity will always try to get back to earth" is rather misleading. It will always try to flow in a complete circuit and get back to the source of supply. If one side of the supply is earthed at source, then the earth just happens to form a convenient path for that current. If you take a system which is electrically isolated from earth (such as the output of a transformer-isolated shaver outlet), then you can connect an earth to either side of that circuit without there being any flow of current* to earth through that connection.
* Ignoring insignificantly small currents due to leakage, capacitance, etc.
I test everything before I touch it, but i use a multimeter as its all i have. I use nearest earth (earth or central heating pipes) as a reference and when that shows safe I also use myself as a reference as a second test. Then i work away. Is that OK?
