Keep getting called out to fix pin holes in 22mm main in barn conversion. It's a big property with four bathrooms and unvented cylinder. Leaks only seem to be happening on the 22mm. There appear to be many green 'spores' on the pipe so renewal of the whole main is going to happen at some stage. Owner says the conversion was done in 1994 and the general standard of the installation seems quite good. I know that excessive flux use can cause this,but could there be other issues? Only the cold main is affected at the moment. Any suggestions gents?
