Pine worktops for kitchen - how to stain/oil/finish
10 May 2016
Hello. I have just had pine kitchen worktops installed with a belfast sink. So now I need to finish them with the appropriate oil/stain/varnish/wax/lacquer etc, etc.
Can someone please point me in the right direction?
- Should I oil first, then varnish or seal?
- Is oil alone enough?
- How many coats are needed?
- Can anyone recommend the right oil or varnish that would be best suited to a kitchen worktop?
Many thanks!
2 Dec 2017
its a bit late in the day - the oiling/sealing should have been done before installation except for the raw, cut-out edges.
contact the suppliers/ installers for advice.
10 May 2016
They are only resting in the cabinet plinths at the moment. So can easy be lifted up.
Why do you not oil/seal the cut edges?
Any advice on the right products?
15 Sep 2017
S. Uplands
I believe the current trend is to use Osma polyx for worktops -which I think is more oil than varnish
I dont know if that will increase the yellowing of pine though.
You cant oil and varnish -1 or the other.
oil -looks more natural, but needs regular attention, can easily be sanded and reapplied
varnish -creates impervious layer but looks plastic and once damaged needs stripping.
14 Mar 2006
Kent
OSMO TOP OIL
Used on kitchen top , 2 years later still as new .
15 Jun 2004
Norwich
If its fresh wood, you will need at least 4 coats of oil, rub down well between.
I use Danish oil. (On Bamboo wood)
2 Dec 2017
you treat them before fitting an make the cut-outs afterwards then treat the cutout edges.
10 May 2016
Thanks.
Will Osmo be okay on pine?
Or is that more for hardwoods?
I understand marking/dents is more likely as pine is soft. But don’t want the ‘plastic’ look of varnish.
11 Aug 2010
All oils will somewhat darken any/most??? woods (the equivalent of the wood being wet). But pine will also darken by itself irrespective of what you put or do not put on it. Check out pure tung oil (at least the Liberon version I believe is food safe). Other than that you must oil frequently else kiss your worktop good bye.
