Hello
I have a bracket fix stair system - all going well, but about to start the spindles. On the accompanying video, it says "the spindles are held in place by the fillets and glue" (i.e. the spindles are just glued in) but in the printed instructions it says "cross pin and glue spindles". Does it matter if they are just glued? If I do need to pin them, what size nails should I be using? Do they go in at 90 degrees to the rail through the spindle? And finally, should I be using the same size nails to go through the fillets and do these nails have a head or are they the invisible type?
Thanks very much. Hope someone can help.
Helpline closed on a Sunday!
