pipe capped off
12 Feb 2008
Birmingham
couple of weeks ago i fitted a pump to increase pressure to a shower. I routed the hot water directly from the cylinder as per the instructions. Originally the showers hot water was fed from the same pipe that supplied the bath n basin. I removed the pipe section to the shower & capped it off. So now i have a 100mm pipe section, full of water, that goes nowhere. Is this gonna cause problems? salmonella legionaires or what ever!? :shock:
Gary, if you're not happy with the 100mm tail, remove it. Legionnaires is most active between approx 20 - 45 deg.c . The chances of this small dead leg becoming a breeding ground for anything is slim, but if you aren't happy, take it out :)
Legionnaires is most active between approx 20 - 45 deg.c . The chances of this small dead leg becoming a breeding ground for anything is slim...
But it seems likely that the temperature of the water in the dead leg will always be in the range 20-45°C. :shock:
