I am attaching a new external light with intergral PIR. I have connected as per instructions with L, N and E going into the connection points in the light. However, the light does not come on at all.
After much fiddling with the sensitivity, and putting it into "Photo" mode (dawn/dusk sensor) and then covering the light sensor to fool it into thinking it was dark, the light does still not come on. I have checked the bulb - no problem there.
I have also disconnected completely and then rewired it to a 3A plug, and plugged it in to a mains socket. again, nothing (even in the dark in photo mode).
On closer testing I find that the light flickers on for approx 0.25 sec when switching on at the mains socket, and if I switch slowly, find that it will do this when switching on and off (i.e. the light comes on when the switch is between on and off (if you press the mains rocker switch slowly).
Has anyone any thoughts....it seems to me that the PIR is not working (I have tried the above in test mode, security mode and photo mode all with the same results.
The light is a Focus DIY IP33. I have even taken the original back and exchanged it, but the 2nd unit gives the same results. (At the same time I also bought the same light, but without a PIR and connecting to the mains in the same way sees that come on when switched on at the socket - exactkly as you would expect!).
Any thoughts anyone...this is turning from a simple job into a marathon (much like this post!)
thanks!
thanks!
