PIR with LED
16 May 2005
Sussex
Have purchased a stand alone PIR, MI state no lower than 25 watts
the LED exterior fittings are rated at 6 watt each wanting to fit a pair.
Is it plain that the PIR will not operate correctly?
Is there a PIR that will switch such a low wattage?
Cheers
Will probably flash on and off. Just try it. It won't cause any harm. I suppose you could put a reistance into the circuit, but, sorry, can't tell you what.
Better quality PIRs have relay-switched outputs and do not care about minimum loads.
Best you take that back to the shop and get one that does not have a minimum load.
