Ok. You are pretending not to understand.With respect, you're either being silly or not reading what I write. Of course I would not be able to use 'low-rated' plug fuses if they didn't exist (either because they weren't manufactured or because I lived somewhere that did not use plug fuses at all). As I said, I do live in a country which uses plug fuses, but I would not use anything other than 13A ones if I did not think that there was a potential benefit to be had by using lower-rated ones.
If you lived in a country where plug fuses are not used - AND you had not had it drummed into you that the smallest one should be used - would you consider it necessary to engineer your own?
Yes, you did, and with respect it was a silly thing to say.Everything, I would have said. You said that the issue of plug fuses only arose because of ring finals. In response, I suggested that unfused plugs on a 32A radial probably would not be regarded as acceptable.
That would not be the alternative.
I can understand but am trying to elicit a positive example of this conceivable upside. Surely you can work out a scenario.If neither of us can think of a positive downside, but I (but not you) think that there is conceivably a positive upside, can you not understand why I feel that one might as well do it (given that it essentially comes with no cost).
I don't follow why that would be necessary.It may well have been considered 'impractical' in countries which do not have fused plugs, since it would presumably require the installation of multiple 3A circuits,
What has the 'wrong' socket got to do with it?and probably the invention of some new plug/socket to prevent things being plugged into the wrong socket.
Would it not have been within their wit to just make a plug into which a fuse could be fitted - like they did in Britain?
Have you?I have repeatedly explained what 'potential positive upside' that I see.
Example, please.In the absence of downsides, a 'potential upside' (even if only slight) swings the balance in favour of that approach. It may conceivable occasionally do good, and the 'worst' that can happen is that it provides no benefit.
Shouldn't the analogious choice be between two which will save their life?Think of a person with a serious illness who is offered a choice of two treatments. There is no known downside of either, but one of them might conceivably (but very probably not) offer a slightly greater chance of saving their life. Which would they choose?
