- Joined
- 27 Jun 2020
- Messages
- 39
- Reaction score
- 1
- Country
Good point, I have considered this and appreciate it will certainly be a lot more difficult and time consuming than if there was more space to work with. I've tried looking for guidance in this area actually but not really came up with anything helpful. I know it can be done as I've seen many example of this being done but I certainly appreciate it will not be easy. I was thinking of just doing a few courses at a time and trying to point them up as best I can with the access before I start the next course. Am I being too naive/optimistic? Do you have any advice on this? I'm hoping you do, and appreciate the help. ThanksHaving just built a garage myself, have you considered the challenges of building that close to the boundary? or do you have access through next door?
My god, you must have balance like a cat! I'm guessing you wouldn't recommend that to others? lol That's another point actually, I guess tiling the roof will be more challenging than laying/pointing the bricks.Fortunately the roof will be about the fence line and if I ask my neighbour nicely they may allow me to do the first few rows of tiles from their side, if not I'm hoping there is someway to do the first few rows from the inside, but obviously it's not ideal.. hmm I need to do some more thinking here..I walked on the larch lap panel arris to roof mine.
Yes I think it will be tight, to say the least, but for several reasons it really needs to be as close to the boundary as possible. It will actually be 125mm from the boundary on the edge where the gutter will be, the deeds do say all sorts about overhangs and projections for foundations and gutters, but I'd like to keep all parts of the building on my side of the boundary anyway. I'm planning to use mini guttering which is 76mm wide, the garage will be 3.2m wide, I guess this would be ok in the main? maybe the occasional overflow?If your wall is 100mm from boundary, time you've got soffits etc on the gutter will be well over the boundary. Which your neighbour could object to and prevent you from constructing that element. Best have a rethink of that one...tiling/slating from inside would be tricky once you've put the membrane on![]()
I think I'm also going to have to put the membrane on in sections as I go for that side
