Planning Permission Documents for House Extension
2 Jan 2013
Yorkshire
Hi all,
Im currently applying for planning permission on the planning portal site for a single storey extension to the back of our house.
Its a detached house, the extension is arond 3.2 x 8.5m and it should be pretty straighforward as its not on the boundary, no trees etc.
Ive had a pre application discussion with my local authority who confirmed permission was needed.
Ive filled in all the forms and uploaded a 1:200 and 1:1250 site & location plan. What I cant seem to see is what else to I need? I was going to submit a existing/proposed floor plan at 1:50 and also a existing/proposed elevation.
Is there anything else that would be needed as there doesn't appear to be a definative list.
Also as I work in construction, (although not dealing with planning issues) Ive drawn the above up myself by hand. Although not to a totally professional standard they are neat, legible and accuratly to scale, I presume this will be fine?
Thanks for reading and I look forward to any comments.
Ben
You need to check the national, and more importantly the local validation criteria, as this will state what documents your council requires for them to accept your application
There should be a link on the page to upload documents. Or check your councils website
Typically, all elevations showing neighbouring properties, and full floor plans, and you may need to mark trees and fences etc
You need to bear in mind that the Planning Portal is simply an online centre for preparing and submitting application to your local authority. As such you should refer to your local authority website for their specific requirements. (The Portal tends to give you a link to your authority website if you do not already know it.)
Generally speaking local authorities will want to drawings to a recognised scale. They do not need to be computer drawn as long as they are accurate. You will need to ensure that there is a scale bar or failing that you can always add dimensions to your plans.
You will generally always need existing and proposed plans and elevations as well as a block plan and a site location plan to appropriately describe the proposal. For a householder application you will not normally need any further supporting documentation that may often be required with other types of application.
Are you extending 8.5m off the back of the house - or is that the width?
