Hi All,
Not strictly DIY because we're not planning to do it ourselves, but would appreciate some help/advice. We're going to get a loft conversion, and have paid for some plans to be done. We then got some local builders round, who said that:
a) the measurements were wrong, and
b) the drawings were only building regs drawing and couldn't be scaled off.
Part of the problem is the head height. Without lowering the ceilings on the first floor we'd have about 198cm i think. The planners said it would be fine, and when i said builders had said it wasn't and it wouldn't pass a building inspection, they said they were planning some sort of footwell where the door was so that it came in under height. But this isn't on the plans.
So i have a few questions:
1) Should the 'footwell' solution described be on the plans. Appreciate you probably need to see the context, but any thoughts welcome.
2) generally, when you pay to have plans done, should you expect to get drawing that say 'for building regs only, do not scale off' or should you expect to get drawings that a builder can scale off?
3) I've already asked for a refund because the service has been terrible and the plans are wrong, but is there anyone i can go to if, as i expect, they don't give me a refund straight away? How can i prove the plans are wrong?
Thanks!
James
Thanks!
James
