Plaster over damp walls
6 Jun 2017
Hi
We've removed all the wallpaper in the room which we are getting re-plastered by a plasterer. The wallpaper was damaged by damp and I wonder if there is anything we can do to protect the new plaster from damp? Either before or after plastering. Or should we use a specific plaster?
Also, there are some bits of the wall that are painted and some (under bay window) where it's a wood panel. How to we prep those bits before the plasterer come? Or will he do that?
Thanks!
JohnD
Do you accept rounds of applause?
15 Nov 2005
South
Cook Islands
you have to find the cause of the damp and fix it.
the most common cause is condensation, resulting from hanging wet washing around the home and/or insufficient ventilation.
but round a window it could be rain penetration, especially if a bay
post photos and descriptions of the damp. Including the outside and the roof and gutter.
11 Jan 2004
Blocked gutters or leaky flashings are often culprits.
1 May 2007
Hampshire
Nobody dries their washing in their homes... and they always open the windows.. I was reliably informed...hundreds of times
7 Mar 2016
Ireland
OP,
Read back and research your issues on previous threads on here and the building forum.
Then come back with the relevant & variable info.
eg.
is the house rendered?
what floor ?
solid floor?
solid walls?
rads or appliances in the room?
"damp" without further information means nothing - there are various kinds of damp and condensation.
30 Jun 2009
Londonderry
The sensible solution to this, is to establish what is causing the damp issue. Re-plastering would not prevent this. It could be caused by a leak, externally or internally, it could be rising damp, it could be condensation. Absolutely no point doing any plastering until it is resolved.
