    Dismiss Notice
plasterboard to wall
Discussion in 'Plastering and Rendering' started by Paulboy, 2 Jun 2007.
  1. Paulboy
    Paulboy
    30 Nov 2004
    231
    Thanks Received:
    Country:
    if i am having a room plasterboarded(on to brick), which is the better option..?
    Either have the wall dot and dabbed or use battons and screw the plasterboard on timber battons on the wall?, oh and ive gone and brought 9.5 mm plasterboard for the walls (got kitchen and bathroom to do, will this be ok as opposed to 12.5mm ?
  2. Sponsored Links
  3. noseall
    noseall
    2 Feb 2006
    41,152
    Thanks Received:
    2,570
    Staffordshire
    Country:
    definitely d&d. 9.5 should be ok, but be sure not to skimp on the dab.
    the only time battening would be more beneficial was if you needed to fit foil backed (duplex) boards or needed to include insulation behind the boards.
  4. rdw exteriors
    rdw exteriors
    26 May 2007
    19
    Thanks Received:
    Bradford
    Country:
    dot and dab much quicker and easier, 9.5 is fine
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
