plasterboard walls vs ply walls
1 Oct 2007
Hampshire
Is there any risk involved with using plywood for a wall that your going to tile as opposed to plasterboard? I would like the additional strength it offers.
Sam.
It depends where it's to be used and why, it offers good fixing for shelving etc but offers no benifit in wet areas where plasterboard should not be used either.
Its just a WC. So no continuous water coverage like in a shower area.
I'm tiling so its easy to clean (I'm lazy, slop slop clean). The walls are thin and crappy, so I'd rather use ply for the strength.
sam.
.... in wet areas where plasterboard should not be used either.
Balls. If you tank it, there's no finer substrate - it's cheap, quick and easy to fit. Once tanked, provides a 100% waterproof wall; rather than just the water resistant wall you get with tile backer board.
