Hi
I have a small plumbing job to do but have an issue identifying the existing 15mm plastic pipe/fittings.
I need to insert a tee into a 15mm existing cold water supply pipe (plastic) but do not know the 'manufacturer' of the pipe.
I am aware that the push fit fittings are universal but the pipe inserts are not.
How do I identify the pipe and subsequently the inserts? There is one other fitting (straight connector) visible but looks like a plastic compression. Otherwise the only apparent other clue is that the pipe is black !
Any help?
SjH
Any help?
SjH
