how can i install a 100mm plastic toilet branch into a plastic soil pipe if i cannot lift or drop the existing pipework?
do they make a special joint that can be used?
The coupling is a called a slip coupling, it looks the same as a normal coupling but is smooth on the inside to let you slide it out of the way. You will need a branch, I would use the access type, and also a pan connector.Sizes are 110mm.
