Plastic toilet cistern urgently required!
7 Jan 2009
Nottinghamshire
anybody know of any stockists who sell plastic toilet cisterns, close coupled, and bottom entry valves??
all the places ive tried are for order only.
urgently required before christmas!!
cheers
you dont only get a close coupled cistern what you can also get is a low level cistern and a close coupled kit, try screwfix, i THINK they do plastic ones
no as the connections are different but if you are desperate you may able try and jury rig it but not sure how as i have never tried
Am confused as to why you think the connections are different - to my mind you only need to attach the base plate to the flush outlet as per norm. Where am I going wrong in my thinking :?
plumb center sell some plastic cisterns take the one you got to them ask if they have any like it
as i understood it, close coupled cisterns have studs built in to allow for the wing nuts which pull the cistern down onto the pan, i didnt think low level cisterns have the studs, however it appears im wrong as the studs are seperate and connect to part of the close coupling kit!
The metal plates have these recesses built into them - the base of cisterns are flat.
i am pretty sure close coupled have a bigger outlet than low level one`s
saying that you could always take hole saw to it and drill two hole`s for the bolt`s
