Hi everyone - have been really impressed with all the useful information that I have gleamed from here so far, so I thought that I may get some support with my house wiring. I am currently assessing the heating at home and bills, I am on Economy 7 with storage heaters and not impressed. Now, the heaters are traditional dimplex units with input control and boost control - no additional convection heating and are wired into the wall with an on/off switch
Questions:
From looking at my wiring - how is Economy 7 set up, if you can tell. Will I have a day/night circuit. Or will it all be radio timed for cheap rate during economy 7 hrs? If it is the latter, with everything being on 1 supply - how can I avoid my storage heaters caining my supply during the day?
Here are some screen shots of my wiring:
My main supply where the meter is:
Does it look like I have a 1 supply that is radio timed, or a separate circuit for the economy 7?
My main board:
Just for interest really. Storage heaters are on their own RCD on the board.
Here is my usage data for a typical days supply with my storage heaters on:
As you can see my storage heaters seem to be hitting the supply in a cycle all day, rather than just charging at night as I would expect with the heat dissipated during the day.
Another day, with heating on, set lower - but you can see that it is almost like the storage heaters are 12 hrs out of sync. Am thinking that if I have a radio timed second supply feed for economy 7 for the storage heaters that it may be out of sync? My day rate usage compared to night time usage is huge - considering that the property is empty during the day (hence doing this investigating.)
Here is my supply summary for the past week or so, any comments greatly received, are the daily totals about right for running 2 storage heaters - 1 1.5KW, other 2KW?
My current usage summary:
Am happy with the spike, as this is my hot water immersion coming on for 40 mins between 0545-0645. Note the 16p rate represents a single tariff - it cannot log Day/Night rates together.
Has anyone got any thoughts - should I get the economy 7 radio timer checked by my supplier - if so, how do I go about doing this as my supplier have said they're not responsible?
I have not got mains gas - should I look at installing another electric heating solution such as Rointe http://www.ecoheatingcompany.co.uk/rointe-radiators and changing to a non E7 tariff such as Eon?
Incidentally all the data logging was done using the fabulous products from Alertme.com - been finding this really useful to unpick what is going on with regards to my supply. But you can see I am drawing much more during the day, due to my heaters than I should.
Anything that anyone can suggest would be much appreciated.
Dom
Questions:
My main board:
Dom
