I don't think so. If I understand correctly, things that we would call CH boilers appear to be called 'furnaces' over there.I‘ve been told furnaces in the US heat air while boilers heat water.
I don't know what americans would call what we call a "boiler".I don't think so. If I understand correctly, things that we would call CH boilers appear to be called 'furnaces' over there.
Plocket, Plet, Soug, socklug. Perhaps a matching pair should be Soug and Guos? they both sound a little French.The French have plug sockets, the part connected to the appliance has a socket for the earth pin, but the lives plug into the wall plug socket. So since both parts can be given the name of either plug or socket, it seems to make sense to have some unambiguous name.
Is a furnace the best possible furn?We however, have a whole host of names which don't seem to make sense. Boiler for an item which, if it boils water, is considered faulty, the USA furnace does seem a better name.
Werrll I were brunged up nowin':I must admit that I was brung up with the saying "Bulbs go in gardens and lamps go in lampholders"
That is how I understand it tooalso plugs plug into a socket
Yes, I totally agree with all that, but ........ But afaict "wet" central heating systems like we use in the UK are unusual in the USA. Americans tend towards "central air" systems, where heated or cooled air is pumped around the house. The "furnace" is the component of the "central air" system that heats the air.
The US terminology seems a bit confused/confusing, such that I didn't know the answer to that, so I consulted Mr Wikipedia and if what he says is true, then it seems that they may well call that a "furnace" as well ... (with my emboldening) ....I don't know what americans would call what we call a "boiler".
Buildings
- Furnace (central heating): a furnace, or a heater or boiler, used to generate heat for buildings
- Boiler, used to heat water; also called a furnace in American English when used for heating and hot water in a building
I don't know, so you may well be right.That is my experience, however if my understanding is correct their wet system are - or possibly were - more commonly steam powered and their radiators were in the early days mounted high up.
