Hi all,
I am preparing to screed my concrete subfloor, having pulled out the old one which was uneven and full of redundant pipework.
I am the top-floor flat and there is a riser for the soil pipe, mains water feed etc running inside the flats. There is a gap between the structural concrete subfloor and a lump of concrete blobbed on to these services.
Obviously, I do not want to chuck a load of screed down this gap, as it will simply fall down to the next floor or further.
A builder suggested stuffing some newspaper there and then expanding foam, trim and put the screed on top. I am concerned that it won't support the screed (70mm 1:3 cement:sand).
You can see that the gap is ~70mm on one side and ~100mm on the other. There's nothing to offer support in that void. The floor slab is ~110mm or more thick.
Timber framed walls that will surround the riser need to be built directly above those gaps (due to where windows are).
Can anyone suggest how to plug these voids so that the screed can go right over? Will expanding foam on newspaper really hold that chunk of screed??
Many thanks for any advice or views!
