What exactly do you think is the purpose of the cpc?
Of course, because it would be. Depending upon the extent to which you'd undone the nuts and many other factors, it could easily result in disaster very quickly. That I call 'immediately dangerous'.If I undone all the nuts on you wheels and you drove up the M4 at 70mph would you say it was immediately dangerous and lives were at risk.
Hint: one of the clues is in the 'P'.What exactly do you think is the purpose of the cpc?
That's Irony.I got an interesting tingle off the boiler pipes when I turned it on after the sparky had rewired, and just before the trip for the lights tripped.
A neutral was was trapped in a light switch.
What was your second point of contact or was is capactive coupling ?I got an interesting tingle off the boiler pipes when I turned it on after the sparky had rewired, and just before the trip for the lights tripped.
Totally out of control of the people in the building and turning the power of at the main switch does not remove the danger. The damger remains until the DNO isolate that section and ground rod their neutral local to consumers. Rare event but not insignificant,Big job just outside Bath, a phase went down neutral on the pole, every fitting in the building was live
You tell me, most if not all controls don't need.
Programmable stats don't have one.
Some stats are volt free, you just replace a link with a stat, timer or both.
But what or who are you protecting.
Why don't you need to bond baths, towel rails etc if they are piped in plastic.
Who do you know that got a belt of a volts free room stat.
..and also (particularly if an RCD is present) there is the person who accidentally cuts, otherwise damages, or puts a nail through, the cable.You are protecting anyone who uses or work on the installation. You are also making sure that your work is compliant with all applicable regulations.But what or who are you protecting.
Bernard, I'm a bit confused about your having thanked doitall for his post at 11:25pm last night. Were you really meaning to support his view that it is OK to have fixed wiring cables without CPCs - since that is the impression given (at least to me) by your thanking him?The following user says thank you to doitall for this useful post: bernardgreen (today)
