Plumbers. Bless them.
Copper pipes can leak and they're allowed.
And they can corrode.
As happened to a gas pipe of mine - installed by a Corgi registered guy, all signed off etc. He ran it through a breeze block wall with no sleeving, and it got eaten away.
Fortunately the smell of escaping gas alerted us to the fact that there was a hole in the pipe.
I thought the regs was supposed to be harmonised with Europe. ?
I know little about this. Yes, there is certainly a degree of harmonisation, but the fact that there are fundamental differences (particularly between UK and the rest of Europe) as regards wiring practices, the same regs clearly can't apply Europe-wide. For example, ring final circuits and fused BS1363 plugs only exist in the UK.
Lets assume you guys are correct, what percentage in the uk would you say doesn't comply, being installed before the change 80-90% perhaps.
Most installations wired prior to 2008 (and many wired subsequently!) are probably non-compliant with current regs in at least some details. However, there is generally no 'retrospective' requirement to upgrade things which were compliant with previous additions of the regs to make them compliant with current regs. As I understand it, the main issue arises when one 'does work on' a circuit (or part of a circuit) which is not compliant with current regs - in which case there is sometimes a requirement to bring it (certainly new bits of it) into compliance with current regs. As in most walks of life, if one went around with a fine toothcomb and a 'jobsworth' attitude, one could probably find at least some non-compliance with current regs, at some level of detail, in almost all electrical installations. The same may well be true of plumbing/gas/heating installations.
Kind Regards, John
Indeed- and as someone else suggested, I would imagine that the solder in copper pipe joints will melt at temperatures very likely to be experienced in house fires and, indeed, at temperatures which quite probably are not all that much higher than the temperatures that would destroy a plastic pipe.
Hence, whilst copper is intuitively ('gut feeling') 'safer' than plastic, I'm not sure how much 'thinking through' that intuition can actually stand.
Kind Regards, John
... what about an old CU with real fuse wire.
AIUI ...
Neither being old, nor having fuse wire, is prohibited by the regs. It is (contrary to what some people might believe, or say when selling you an upgrade) quite possible to have an installation which uses an old(ish) CU & rewirable fuses which is compliant with the current regs.
The fact that it's generally easier (and possibly cheaper) to bring an installation up to current regs by swapping the CU for a 'modern' one with MCBs and RCDs is a different matter altogether.
AIUI ... Neither being old, nor having fuse wire, is prohibited by the regs.
That is certainly true.
Firstly, there obviously is no general requirement to make the installation compliant with current regs, if it were compliant when installed. However,if you did want something fully compliant with current regs, it probably could not be done with 'just' a single 'old' CU (even if it satisfied current requirements - e.g. IP-wise etc.). For example, some of the final circuits would almost certainly require 30mA RCD protection, but current regs also effectively 'prohibit' all final circuits being served by the same RCD. Whilst RCD protection could be added by an RCD external to the old CU, there would be a need for at least one other CU (or some equivalent), and perhaps a second RCD, to provide OPDs to serve other final circuits.
Yes, it's a totally different matter - although, as you say, in practice a modern CU would almost certainly be simpler and cheaper, if one wanted to end up with full compliance with current regs.
Kind Regards, John
Just a small injection of something positive - my 50 meter roll of .5 x 5 core cable arrived today thanks to this post. Marginally more expensive i will be fitting WiFi stats with it in future complete with its redundant cpc. I will also be wording a phrase for my invoice should I find ( and I will probably at 2 a day!) explaining the position of sleeved cpc's etc to cover my bum.
If running a 2 core cable 20 meters to an external WC (weather compensating NTC) stat from the boiler wiring centre, or a 2 core cable from a volt free connection in the wiring centre in the boiler (not the 10 way box) would that flex require a cpc?
Certainly there is no excuse to do it incorrectly on a new install or if fitting extra bits n bobs to an existing install.
thanks
DIA: Didn't you agree 20 pages back that there was no more to be said on this topic? :wink:
Volt free means that the switching device (be it a simple stat or timer, or a programmer) does not provide a voltage to whatever it is switching. The appliance, e.g. the boiler does that - it has 2 or more conductors running to the switching device which makes and breaks connections between them to fulfill its function.
Just like the light switches on your wall - they too are volt free, but they have 1 wire which is permanently live, and one which becomes live when the contacts close. The boiler might be asking the programmer to complete a 12V circuit, or it might be asking it to complete a 230V one.
But it is not true to say that there is no voltage between conductors and therefore between switch contacts at the programmer - if there wasn't then no current would flow in the circuit when the contacts close and therefore it would do nothing.
If you're installing fixed LV wiring then there should be a cpc, even if at one end there is nowhere to connect it.
LV being 240 and not 24 v as it is seen this side of the fence makes sense but the expanation for the unused cpc was that at a later time the 'switch' may be changed for one needing a cpc. If the source of the 'flex' is indeed the boiler wiring centre requiring only ELV contacts or in the case of the NTC with negligible current and voltage (DC in this case) flowing , the Manu still require .75 flex.
This surely does not need a cpc? (I am not being argumentative here just trying to get a definitive answer)
yes mate, had to give bas time to scour the books in the loo, he's a bit senile now and reads very slowly.
Normally he would just copy and paste a dozen or so books but I think he may have forgotten how too. :wink:
As has been explained, the Wiring Regs appear to require a CPC for any fixed LV wiring, with the single explicit exception of the drop to a fully insulated lampholder in a pendant light. So the answer has to be 'yes'.
Kind Regards, John
Strange how someone who has put me on ignore is still so concerned about what I might or might not be writing.
