plumbing and central heating
27 Mar 2009
Devon
hi I have just fitted new bath and i used 22mm flexi hoses to connect to bath taps, to make job easier. I am using shower hose connected to bath taps. Problem is now i have low pressure coming from shower . Would the flexi hose reduce pressure as it has smaller bore than 22mm pipe. Or is it to do with head pressure? Thanks.
Does the pressure increase if you lower the shower head?
What is the pressure like to the taps?
HI THE PRESSURE IN THE TAPS IS QUITE GOOD, COMPARED TO SHOWER HEAD, WHEN LOWERING THE SHOWER NOZZLE THERE IS NOT MUCH CHANGE IN PRESSURE, IF ANY? TA.
