PME understanding how it works
10 Jan 2007
Sussex
Dear list
I live in a mid 70's house here in Sussex UK.
Some of the water pipes are indeed bonded together but not all!
Am I PME or not?
I ask as I am currently working on a radio based matter that may have a large influence depending on the type of house wiring.
If I measure between Negative and Earth there does seem to be a connection of say 100 ohms or so, along with this there is a varying AC voltage of 30 mV, hardly any current.
Mike
Can't say from that information.
If you can post a photo of your service head, and consumer unit etc, we will be able to get a much better idea.
It's neutral, not negative.
Also, with a PME system I would expect there to be a very low resistance between neutral and earth, certainly not 100ohms due to the earth originating from the PEN conductor at the intake.
This does however depend on what and where you're measuring and your chosen instrument. Is it calibrated?
Between which neutral and which earth are you measuring?
Would the radio based matter involve a separate earth to mains fed equipment by any chance?
Is it 'hi-fi' based radio or HF/uhf radio?
