pointing mastic
7 Jan 2011
Hi all
Can any of you be so kind as to point me in the right direction for buying
red mastic for pointing brick.travis perkins do the trowling mastic but im looking for the stuff i can use out of a gun.
also does the linseed oil i will need go all over the brick and the mastic or just the mastic. :?
Yes i am a novice at diy so please accept my apologies if this question seems daft to you.
Thanks in advance :)
trowing mastic is a pain,i always try to avoid it by using cement dye and going that way about it if the cutomer agrees.
put the linseed oil on a cloth and work it on brick and mastic,dont put it on with a brush as it can make a right mess.
