polyorc plastic pipe
12 Dec 2007
Southampton
Has anyone seen this plastic pipe i know its from the seventies, but i have a 2inch peice that i need to connect a plastic isolator (long story) Which pipe can i use for it ABS or PVCU? any help would be appreciated. :D
Hi the name for the pipe is polyyork 3505 and was used a lot in the 70s i have intalled loads up o 4" it needs a special glue there are fittings that will fit but it will need a lot of searching around you might be able to use a 2" compession fitting or simular but you will have to fit a sleeve inside so the olive has somthing to crush onto
THte normal size used in domestic pipes is classed as 3/8th polyyork and a leadlock type of fitting fits these ok
best of luck
mick
