Hi all,
I was looking at the pool power box, which looks like the following:
Notice on the right transformer, all that rust and crap around the two fuses (in the transformer) - is that very dangerous??
Also, the lights havent been working for ages - a while back they did turn on properly, but since have not. Perhaps the fuses in one/both the transformers have blown???
That black fuse switch bottom right is the main one for power to the box, the white one is for the lights, and the two black ones above that I think are circuit breakers for the two lights (underwater 32v pool lights this is).
The timer on the left there (black box with green and red pieces and the dial), works in that if i manually turn the dial, when it hits the red piece the power is stopped to the powerpoint below it, and likewise when it hits the green piece the power comes on. BUT, the actual dial doesnt turn - ive set it on say 12 o clock, come back in a few hours - but it hasnt moved. Would anyone know what would cause that??? The motor inside that turns the dial has gone ??????? Be good to know anyones opinions.
Thanks,
Andrew
Thanks,
Andrew
