You ARE being too optimisticAs the roofer has only replaced the felt and not the roof structure, this would suggest that the pooling problem has been there for years. I can't say that I think your roofer is at fault here, if all he has done is replace the felt.
I agree with part of that answer. The pooling problem may have been there for years, it most probably was! But I would say most professional roofers on here would have checked it before starting work and advised that a new deck was laid with a slope to the outlet gulley. Or am I being too optimistic. ? Suggest you get a surveyor in quick to give you a report in writing.
Indeed flooding a roof with bitumin in some cases can stop the ponding(done it before) but the only problem in this instance would be you would need so much bitumin the weight of all that bitumin may just cause the roof to dip in no time at all.You could then be back at square one.I couldn't help noticing that he has not covered the upstands to the wall with any lead he seems to have just pointed in the top of the felt which in time will leak.As for the pooling he could have flooded the roof with bitumen which would have levelled off the area and then felted on top of it
Sound advice.The roofer should of got the outlett a lot lower and formed a propper lead spitter...thats a stupid amount of water and could be cured at least 75% by 1st sinking the lead outlet into the board 10mm and not felting all the way into the wall, so in effect you have a small step down where the lead is....I can also see future problems with water penatration through the coping stone which idealy should of been capped with a brindle colour mineral to match brickwork but stopping 50mm from front edge so it cant be seen from ground level..As been stated by cumbrianroofer its a very poor quality job imho![]()
