Poor mains water flow
29 Jul 2007
hi guys looking for some advice.
i live on in 1st floor flat and have poor mains cold water flow, sometimes zero water at the tap.
i have contacted the water board many times with this and now they are claiming to have the required flow/pressure at the street stop cock, and are pointing the finger at the pipe that supplies my building.
after some investigating i have discovered the pipe from the main supplies my neighbour below, which makes sense as i end up with no water when he is drawing some.
after looking into getting a new pipe from the main fitted i very much doubt i can afford to :(
basically am looking for alternative suggestions to solve my problems?
yes i have access to the loft. i thought a tank would be a option but thought it wa maybe to simple to solve the problem :roll:
easiest way tank fills when others ain't using water
you in effect will have your own supply
slight downside is you may not have as much pressure :idea:
prob no worse than you have now tho
how would i be able to find out? i used to have decent flow and pressure when i first moved in?
i've no idea? am going to renew my stopcock incase its collasped.
Could always pump it out of the tank of course.....
was keeping that for later :lol: :lol: :wink:
Yeah yeah... :roll:
I'd fit a coffin tank like this one (size depends on usage requirements)
and a Salamander ESP 120 CPV Single pump
What do you have in the way of water outlets (taps/washing machine/dishwasher/shower/bath etc etc)? How is your hot water heated?
would a wrsa tank without a pump be safe for drinking water? and if it was pumped its not?
thanks
The best way is to fit a cold water accumulator cylinder and a combi. There are no pumps with pressure and flow guaranteed if the static pressures is over approximately 1.5 bar.
Using a tank, a cylinder is still needed and a pump for a shower. A lot of um-ah for not much at all.
