Hi there,
We have recently had an extension built and ever since then, when we turn on our porch light, the RCD in the consumer unit trips. I've removed the light fitting (thinking this was at fault) and installed another fitting and yet it still trips. If the bulb is removed then the RCD does not trip. Is this pointing to an earth fault on the neutral? The wiring for the light is right next to the consumer unit and the electrician has done some rewiring in the consumer unit - is it likely that he may have disturbed something?
Any help would be much appreciated!
Matt
Matt
