Porch with posts
17 Apr 2015
Planning on doing a lean to porch roof across the full width of the front of my house, 10m ish. Any tips on the structure, I want visible oak posts (presumably 6”) then planning on using c24 (5x2 ish or doubled up?) across the top which will be clad with upvc fascia bearing onto the posts.
Any idea on post spacing? The lean to rafter span will be about 1m tops.
What’s the normal approach for the posts, set ‘em into the ground like fence posts, or build brick/blockwork plinths?
Any tips or ideas from anyone who’s seen/done this before welcome!
A university campus that I am familiar with has oak cloisters. You can see that over the years, the original oak posts rotted at the base. So I would build brick plinths and organise the tops to slope for drainage.
Don't make the plinths too small or it will look daft
Struggling to find any examples as mines more of a long run over a bay window and masonry porch, with posts to support the rest. It’s to replace one of those rubbish flat roof supported by metal poles 1960s jobbies.
The posts don’t have to be oak, and yeah I guess I could do more of it in oak.
Any thoughts on wall plate span? Was hoping at least a couple of metres clear span between supports if use a doubled up pair of 5x2s and horizontal ties back to the house wall
Is the brick plinth a pad foundation, then something like an 18”x18” few courses and the post concreted into the middle of it?
Cheers for the replies, just trying to get a vague plan
If you make mono-pitched trusses and fix these to plates top and bottom on the wall, the trusses will be relatively self supporting and a 7x2 timber can be fitted through the trusses to act as a sort of purlin and can span to around 3m or so IIRC
full
