Possibility of laying laminate floor on top of 2 inch polyst
31 Jan 2013
West Glamorgan
Is it possible to lay laminate flooring on top of 2 inch polystyrene insulation.
Have completed two rows and the flooring has started to pop up.
Should I remove the insulation and start again
heeelllooo and welcome bottombass2 :D :D :D
what you have is a thin floor covering around 9mm
you need structural flooring around 20mm to give it full support otherwise it will flex at the joins
