Hello,
I’m looking for some advice.. we’ve recently moved into a new property and have noticed that the soil pipe external to the house is leaking every time the toilet is flushed. It’s partially covered by decking but we can see clearly above the part above decking and have tested it so we know it’s definitely leaking. Almost exactly where the pipe is on the inside of the kitchen is a very bad damp patch on the wall and on the floor. To complicate things, there is failed seal around the door and possible condensation damp behind the washing machine. I don’t think these are all related but they could be.
first and foremost I think we need to fix the soil pipe as I’m sure this is what’s causing the damp on the floor and up through the wall. (I’ve attached pictures). The black tape behind the pipe was covering a patch of wall that hadn’t been fully rendered and was crumbly cement which I think was also letting water in.
Has anyone suffered a similar problem? And does anyone think the damp behind the washing machine could be a result of the ground becoming particularly sodden from the leaking pipe?
Our next steps are pulling up the panel of decking by the soil pipe to have a proper look and then calling a plumber to fix the leak.
Thank you in advance for any advice!
