We have a crazy paving patio which was in situ when we moved into the house. Some of the concrete between the crazy paving slabs has developed holes which I want to fill. Would Postcrete be a good filler for this? Any advice would be very welcome.
I believe postcrete contains stone as well as cement and sand, if your patio cracks are small you might be better to use cement-sand mix.
Also no feathering of edges if you are driving on it, it will break, 2 inches
thick is best.
