potterton 16-22 tripping out
19 Nov 2010
hi there, hope somone can help me on this one, i am a plumber although abit rusty on boiler faults due to living in new zealand for 15 years, anyway here we go.... when the control knob on the bolier is turned on it trips on the main fuse board, i have individually removed wires for pump , valves, stat, timer and wires into bolier and still it trips, the whole front panel including air switch etc have been replaced (got one cheap) still trips.When timer calls for h/w c/h and boiler is off then pump comes on but as soon as i switch boiler on it trips out not giving any time for ignition sequence to begin. gas is present at valve, haven,t heard fan come on due to instant tripping out,i am running out of ideas. please hel many thanks in advance!!! oh also when boiler etc is turned off and when i turn OFF isolating switch next to boiler this also trips main fuse board?!
fan,be aware fan is a posotive pressure and these boilers have several saftey issues you shoul watch out for so if you are "rusty" you need to be very carefull
thanks for the extremely quick reply!!, if i disconnect the fan from the motherboard will this also cause it to trip out and do you know why when i turn the isolating switch OFF it trips out, just trying to answer all questions before i purchase a new fan, MANY THANKS
As this model can be dangerous when not treated correctly, I'd get a pro in if you are not quite up to speed with boilers any more.
i appreciate what your saying and thanks and i am aware of the issues this boiler has but just looking to clarify the fan issues.
