Potterton Kingfisher 11
26 Jul 2008
Berkshire
We a looking to buy a property built 1961. From what we've read we're guessing its a gravity central heating system - the pipes are really big (about 1"). There is a cylinder upstairs, the boiler is in the kitchen with a flue that goes right through the house terminating via a chimney.
Everything in the house is original. If we wanted to replace the boiler for a condensing boiler would the pipework/radiators need replacing. Could someone in the know enlighten us on what would be involved. See photos
of top up tank next to boiler flue, boiler, rad, cylinder pipework.
£2600 in berkshire! wont get much done for that.
Get some verbal quotes over phone for starters by local boys or arrange visits for quotes via estate agents with credit crunch on its way should get some competive quotes and go back to vendors to barter over house price.
good luck.
looking at the pics it will all require replacing, this may well prove to be expensive.
i assume that it is working at present. it may not be particularly efficient by todays standards but i have no doubt that this will be reflected in the asking price for the property.
You haven't exchanged contracts, have you!
I hope you have had a proper survey done on the house and are not relying on the HIPS info! The building society survey just tells them if the price is OK; it says nothing about condition - unless it is so bad they won't lend all the money until some work is done.
With a system that old it is worth getting an independent report on the condition of the boiler, asking when it was last serviced and what has been replaced and when.
Also get 3 quotes for bringing the system up to current standards and then use all this info to negotiate a better price with the vendor. Perhaps agree to split the cost 50/50.
dough!!
"assume that it is working at present. it may not be particularly efficient by todays standards but i have no doubt that this will be reflected in the asking price for the property"
the place has been inspected, photos taken & the op is looking for some leverage.
perhaps it might make sense to demolish the whole building & get permission to replace it with six flats or more.
i really do not know.
if they want to upgrade it its up to them, if they want new carpets its up to them, if they want a new kitchen its up to them.
the point is, that is reflected in the price.
Thanks for your comments
Could someone explain 'why' all the pipework needs replacing if a different boiler is installed? Is it simpley the age of the pipework - now 40 years old - or is it to do with the size of the pipework and pressure or what? Many thanks
It's more a case of worse case scenario! Remember NOBODY on this, or any other site, has seen the condition of the pipes nor if it has been installed as a single pipe or flow/return system so all can only guess.
Situations such as this demand a site visit if any definitive answers are to be given.
