potterton performa 28 fault
27 Dec 2009
Essex
heating and h/w tries to kick in but 60 light stays on , indicates pump but the pump is spinning but ...the fan dont kick in pressure switch seems to be working fine ...... im undecided on a new pcb or a new fan
any ideas all ??
thanks
Check the primary flow switch is making when you run the hot water or central heating.
Whats the system pressure ? even if it reads 1 bar let some water out the system (or top it up) to make sure the gauge isint stuck
