- Joined
- 17 Jan 2021
- Messages
- 1
- Reaction score
- 0
- Country
Hi all,
After some help here. I have done timings of events when boiler fires up from cold (start of program):
09:17 Boiler fired up all ok. Set to Max
09:30 Boiler switches off. Outer casing hot (probably normal)
09:31 Boiler tries to fire up. Sounds like relays/valves are working. Fan starts for all of about 1 sec. this continues for about 10 attempts till finally firing up.
So at 09:33 the boiler fires up properly.
09:37 switches off
09:39 same as 09:31
Note when boiler starts first time from cold it heats to thermostat setting on boiler. I replaced the PCB a year ago. New pump installed a year ago (in airing cupboard).
The issue has started in the last couple of weeks. Once fired up it does the job of CH & HW.
Boiler is approximately 20 years old. No unusual noises thankfully.
09:37 switches off
09:39 same as 09:31
