potterton puma boiler
4 Nov 2010
Bedfordshire
hi guys had new pump fitted last week ,boiler worked fine ,tonight fired up heating worked then no heat ,boiler fires up for hot water still but wont ignite for heating any ideas please ,gary
Could be diverter valve wax capsule .
Could also be main pcb, the one that faces you. Is prone to bad solder joints, have a wiggle with the wires at the top row of connectors, be careful, and see it it kicks into life. You will get a buzzing/arcing noise it this is the case.
I tend only to post one poss solution at a time, multi-tasking is beyond me
I've had some experience (at what I'm not saying)
as for professional, it pays the bills, all this blagging :wink:
More to the point is where are you going to.
