Potterton suprema boiler heating not working but water is ok..
3 Aug 2009
Somerset
Hello
I have the above boiler and whilst it's not a very good one, it has done myself quite well until now. I noticed not long after having a Quartz shower installed that something in the airing cupboard was making a humming/buzzing noise normally not long after the heating/water has been on for a long time. I also noticed that putting on thr heating manually for 1hr, 2hrs or constant wasn't working unless the water was on at the same time..
Anyway, now I have no heating. I noticed that a couple of the radiators were luke warm after I reset the boiler, turned the thermostat up and the gas dial thing (on the boiler). I also turned the ermergen (whatever its called) on and that also made a couple of radiators warm. Assume a coincidence? I also have found that control panel for the water/heating switches are very sticky. But don't think has anything to do with it.
I also turned a switch on some black think in the airing cupboard (shows I, II, II) which looks to control water speed? Well I switched this too.
Now on closer inspection I think it could be the white (is it the diverter valve) thing in the airing cupboard making the humming noise. My guess is that this has packed up?
Suggestions? I was going to buy this diverter value (but about £200) and also look at getting a tado for the water and heating.
Hot water is fine though..
Ideas/suggestions?
3 Aug 2009
Somerset
Oh, and on the white diverter value (if it is this) there is a switch (cant read the label) for manual override, which when pulled across the water light goes off...
14 Mar 2010
Norfolk
I probably do, but with such scant information, I had little to go on from behind a keyboard. That's why with over 70 views, no one has come up with any answer.
30 May 2007
Cambridgeshire
This probably confirms third point...
2/
This is the system pump, leave it at the speed it was originally.
3/
This sounds like the actuator; this turns the 3-port valve on which it is mounted, they can sometimes be removed without a drain. Come back with a photo of it.
3 Aug 2009
Somerset
Right, had a bit of a play and read online. I have set the slider on the diverted to manual so tomorrow morning i will see if the ch works.
Going back to my first post, the ch only works when the hw comes on so I'm thinking its a faulty programmer unit....
Think I'll replace this for a Tado first then look at the diverter...
3 Aug 2009
Somerset
If the white one then it's potterton
Is this "the white one"?... http://www.heatingcontrolsonline.co...v322-mpe328-msv328-p-122.html?search=actuator
If yes remove it from the valve body (two flat-head bolts), turn spindle to mid position and see what happens when CH comes on.
I've moved the position to manual (not disconnected it) and all seems to be working.
Ive read that the Honeywell one will replace the potterton? Easy to fit the whole thing (inc 3 pipes)?
Going to replace control panel and thermostat too as the heating isn't working by itself when manually set..
