Potterton Suprima 40 flashing red light
16 Jun 2013
Berkshire
My boiler is flashing red light every few days. If I won't switch it on for few days its on for around two hours and then the lights is going red for another few days. I don't know what could be wrong. I had heating engineer coming and have a look a this but they are not sure what the problem is. They desc ale the pipes and has changed the little divided bottle inside the boiler( sorry I don't know what's names the part), they have cleaned the heat exchanger as well, but is still going back to red. It costed me so much money already and it still doesn't work. They want to change the heat exchanger but they are not sure if that's the problem. I know they want all the best but I need second opinion. Could you please advise? Thank you
Try a diferent engineer, one that agrees not to charge you if what they do doesnt fix it.
Maybe better to get a fixed price repair from BG.
Intermittent lockout on the suprima generally points to pcb especially if it's the original ,however a correct diagnosis can only be carried out by engineer checking the boiler...
Maybe even incorrect spark gap :wink:
Had 2 suprima's this week with gas peeshing out the rear of the gas valve
Boilers defo manu's delight for spares ...
Thank you for your replyes. I would ask someone to give me secon opinion before changing more parts. The boiler is getting very hot when is on but the main problem is flashing red light and there is no hot water or heating. I have heard that very often it's a pcb board
Although it can be other things I find that in at least 60% of cases its the PCB.
While I will resolder the old PCB as a temporary cheap fix, the new one is far more reliable although expensive!
