Power shower and water heater suitable for small flat?
26 Dec 2007
London
I have a small one bedroom flat (about 44 square meters) with no gas supply other than for communal heating. I'm fed up with the standard immersion which takes up a lot of space together with the water tank and the communal heating which is always breaking down.
I'm now thinking of different ways in which I can get hot water and heat: underfloor heating, a power shower and a water heater. For the last two, can anyone advise me what specification I should be looking out for as there are so many on the market.
It is not a power shower, but an instant electric shower and an under-sink wanter heater for the washbasin and kitchen sink would enable you to get rid of the hot water cylinder, which in a 44 sq metre flat in London is probably work about £10,000 in lost space.
What the difference between a power shower and an instant electric shower?
An electric shower heats the water as you use it, is limited to mains water pressure and flow, and has a max heat output of about 10kW.
A power shower uses stored hot water which is pumped, can give much greater pressure and flow. But they can go through a lot of water very quickly so you need a big hot water store.
or, to put it another way, an electric shower gives you a weedy trickle of lukewarm water, and a power shower gives you a forceful flow of hot water, which has been heated in advance of use, in a cylinder.
it is still an instant heater, so the amount of heat it can put into the water is small. So if you get a forceful jet it will be cool, and if you get a hot spray it will be weak.
